Moving project to V5 grid alignment problems
hi!
I installed Application: kicad
Version: (5.0.0-rc3-dev), release build
wxWidgets 3.0.2
libcurl/7.47.0 GnuTLS/3.4.10 zlib/1.2.8 libidn/1.32 librtmp/2.3
Platform: Linux 4.15.0-29-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.2 (wchar_t,wx containers,compatible with 2.8) GTK+ 2.24
Boost: 1.58.0
Curl: 7.47.0
Compiler: GCC 5.4.0 with C++ ABI 1009
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
KICAD_SCRIPTING_ACTION_MENU=OFF
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
a few days ago on my linux Mint 18.2, today I opened a schematic I have from version 4.0.2 and all the symbols are off grid, when I try to move one of them it goes on grid but not if I make a group-move, copy-paste. And if I go part by part, then I will need to re-do all the wiring (quite annoying). Is there any way to force all the parts and wires back to grid?
Are they slightly off grid, or half-way off grid?
Are you able to find a grid setting where they fall onto grid?
  • If so, know how many of the fine grid points the offset is both x and y.
  • In the fine grid group select everything and then move only the offset correction amount.
  • Return to the default coarse grid (should probably be a 50mil grid if you are using the v5 official libraries).
Hopefully that should get you back on grid.
They are half-way off, I though the same solution, but just ask in case there where a ‘better’ solution.
The grid is in 50mil, and it was the same or whatever was the default grid in the other, my religion prohibits me to change the grid in schematics :slight_smile:
The problem is not all the components are off grid on the same direction, or by the same amount of steps in the 25mill grid, then with this method I need to do it one by one anyway.
Maybe, I started writing a script to do that, which can be found at kicad-utils/scripts/KiCheckSchematic at v5 · bobc/kicad-utils · GitHub
Currently, it only handles the main sheet.
Backup your project before running the script!
Download the repo to your local disc, then do something like :
python KiCheckSchematic.py --proj c:\projects\STM32_new\demo_STM32.pro --fix_grid
it moves the components on grid, but not the nets, here is a picture:
and the parts U5B, R38, C28, D?, R?, C? where on grid before I use it
you can also see, he moves the component but not the reference or the value
Ok, thanks for feedback, obviously needs further work. I will try to look at it this weekend.
