This is a real newbie question but I couldn’t find the answer after searching this forum or google.
Is it possible to move just a corner/intersection between two wires - i.e. making the other corners of the two wires stay put so that the wires become diagonal (or to fix a case where they are diagonal in the first place)? I see that you can actually do this when using “break wire” or to move a junction, but I can’t figure out how to select just the corner point and move that.
For example, how to i move the “kink” on the wire from pin 2 on this op amp without deleting any of the wires?
