I’m using v6.0.4 on Ubuntu and have come across a odd feature (or bug)
In PCB Editor, if I press M to move a component, and then use the arrow keys to move the component up or down, and the use the mouse to further move the component, its frozen on the x axis. I can move it up and down, but not left or right.
Likewise if I first move the component left or right with the keyboard it gets frozen on the y-axis and I can only move it left or right with the mouse.
When I first came across this I thought my mouse was stuck.
Indeed discovered this also recently.
Also if you want to join 2 graphic objects there is a short flash of a circle with a cross which helps in joining the objets together but it is sometimes not very well visible , I think there should be a “snap” that joins e.g. 2 lines and I think there is but it is not always working, at least not with Ubuntu or maybe I overlooked something, an audible “ping” would be nice…
Jacques
