In my v6 design I have one component rotated 45 degrees and the GND copper pour then also follows the rotation and places the spokes with 45 degree rotation.
However when I updated to v7 this does not happen anymore, the thermal spokes do not rotate with pads and the pads are now connected on the diagonal.
Is there some way to get the v6 behavior in v7 for the copper pour and thermal relief spokes?
The project is available here (v6 format, not updated yet): GitHub - korken89/rusty-tracker at ublox
If you open it in v7 without repouring the “correct” (v6) thermal spokes are there and after repour you will see the “v7” effect.
NOTE: Checkout the the ublox branch after cloning.
There’s probably a bug. Some combination of the footprint angle, pad angle and spoke angle (in pad properties → Clearance Overrides and Settings → Thermal Relief Overrides) doesn’t work.
