Starting from the footprint of a Capacitors_THT:CP_Radial_Dx.0mm_Px.00mm , I would like to modify the footprint by simply spreading the pads further away. For instance because the capacitor has a diameter of 6mm but also a wire pitch of the same distance of 6mm. Therefore, the pads need to be moved to the outer circumference of the body.
The problem is that the pad is apparently moving behind the full half blue circle of the capacitor body symbol.
First I would like to know how to fill up the black area where the pad originally was located.
Secondly I need to put the pad on top (on the foreground) of the capacitor body symbol, i.e. the full half blue circle.
Any hints or links are much appreciated.
