Move components when pressing in M
I used KiCAD 9.2 PCB, How do I move a group of components together? I did holding down Alt key while click, then press M, the components ware not moving,
Please help.
thanks
George
I don’t have V9 yet.
In V8 you rectangle select footprints set and then M to move.
You can add/subtract footprint from selection by Ctrl+click.
It doesn’t work in V9?
There is no KiCad V9.2, and there very likely never will be one. Please do try to spell KiCad’s version numbers correctly. (A remark I make around 10 times a week).
M key is working, But, How do I select the component or a Group of component together??
Thanks
George
M key is working on KiCad PCB ver 9.02, How to I pickup or select a component or Group (components), so I can move up??
Thanks
George
According to what I know paulvdh (like me) is still using V8 so if what I have written about V8 doesn’t work in V9 than someone else have to help.
Works in 9.0.2. Rectangular selection, ‘M’, moves…
Version info:
Version: 9.0.2, release build
	wxWidgets 3.2.6
	FreeType 2.13.3
	HarfBuzz 10.2.0
	FontConfig 2.15.0
	libcurl/8.11.1-DEV Schannel zlib/1.3.1
	Date: May  7 2025 02:29:49
	Boost: 1.86.0
	OCC: 7.8.1
	Curl: 8.11.1-DEV
	ngspice: 44
	KICAD_IPC_API=ON
Locale:
	Lang: de_AT
	Enc: UTF-8
	Num: 1 234,5
@GChew Btw, it’s all in the documentation. Of course it is more economic to let others work instead of doing the reading by oneself, right :slight_smile: ? No harm meant though.
and schematic example…
