Mounting hole via error: Pad near pad
I have the 3.7 mm mounting hole via part electrically connected to chassis ground. On the DRC check, it’s pointing to the smaller holes of the footprint claiming “Pad near pad”. I’m not sure how to fix this. There is nothing even close to these mounting holes, just the pcb traces…it’s like it’s complaining about itself.
Hm these footprints still seem to have no pad number assigned to the small vias.
I seem to have only fixed this in the new library not the kicad 4.0.x lib.
Will open a pull request shortly.
PR committed: https://github.com/KiCad/Mounting_Holes.pretty/pull/7
