More than One Value Field?
Continuing the discussion from Components "Superlibrary":
What you can not see from the screen grab is that I added a new field with the same spelling and capitalization of “Value”.
I moved the field up as far as it would go; don’t know if it matters.
Now the Library Reference and the Value field are now different from each other. FINALLY!!!:heart_eyes:
Is this a hack that will get broken in the future?
ON EDIT: This is the text of the library file for the prior symbol and also the modified symbol:
R_1206
DEF R_1206 R 0 0 N N 1 F N
F0 “R” 50 80 40 H V L CNN
F1 “R_1206” 50 20 40 H I L CNN
F2 “01_Qualified_Land_Patterns:R_1206_in” 50 -40 40 H I L CNN
F3 “” 0 0 40 H I L CNN
F4 “MPN” 50 -90 40 H I L CNN “MPN”
F5 “DPN” 50 -140 40 H I L CNN “Digi-KeyPN”
$FPLIST
R_*
Resistor_*
$ENDFPLIST
DRAW
P 8 0 1 0 0 75 -40 50 40 30 -40 10 40 -10 -40 -30 40 -50 0 -75 N
X ~ 1 0 100 25 D 50 50 1 1 P
X ~ 2 0 -100 25 U 50 50 1 1 P
ENDDRAW
ENDDEF
R_1206_1000
DEF R_1206_1000 R 0 0 N N 1 F N
F1 “R_1206_1000” 50 20 40 H I L CNN
F4 “1000” 0 0 40 H V C CNN “Value”
F5 “MPN” 50 -90 40 H I L CNN “MPN”
F6 “DPN” 50 -140 40 H I L CNN “Digi-KeyPN”
$FPLIST
R_*
Resistor_*
$ENDFPLIST
DRAW
ENDDRAW
ENDDEF
