Soon i will need to make footprint for molex 49616-0711 / 49616-0715.
My doubt is if can make edge cut on the footprint to have the connector will be all inside of pcb.
Can you give-me your opinion.
Thanks
Thanks
You will not be able to use the footprint editor to put stuff directly on the edge cuts layer. You can put the required outline onto any other layer of your choice and move them to the edge cuts layer by use of a text editor.
Just make sure that the open ends of the edge cuts lines are on a grid that allows easy connection in pcb_new. (drawing elements in pcb_new do only snap to grid not to other drawing elements.)
