Modify ner class for many nets at once
Hi.
In PCBNEW, I need to change the net class for several nets. I can select multiple nets in “Board setup -> Net Classes” However, I can’t find a way to change the class for all the selected nets. I can do this one by one with the drop-down menu in Net Class selection but I’m sure this is not the fastest way, especially when you have many nets.
Thanks
My Kicad version:
Application: Pcbnew
Version: (5.1.5)-3, release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Use the filters in the lower left section in the Board Setup.
  1. Type some filter string.
  2. Apply filter.
  3. Verify that the filter works correctly.
  4. Use this section to modify the nets in your filter.
Also: Will you be so kind to fix the typo in the title.
Thank you for answering and for pointing out the typo.
In your picture, no. 4 does what I need, “Apply to selected nets” button.
