Hi.
Is there any way to select more than one pin in a footprint (in footprint editor) and modify one or more property for all pins? For example, I need wider pins on an existing footprint and I wish to change the width on all pins.
I use 7.0.1 version.
Thanks!
In such situation I:
- modify one pad,
- right-click and âCopy Pad Properties to Defaultâ,
- select many pads (this one can be included also),
- right-click and âPaste Default Pad Properties to Selectedâ.
In addition to the mentioned âCopy Pad Properties to Defaultâ:
- you could use âPush Pad properties to other padsâ from context-menu
And to give a outlook for next years kicad v8: The properties panel (in v7 available in the board editor) will be integrated into the footprint-editor - so changing multiple pads at once is possible with that properties panel. For interested uers: the current nightly version already contains the panel)
Thanks. Both answers are very helpful.
