I’m new to KiCad, apologies if its a stupid question but ive been stuck on this forever! My program doesnt have the netlist button at the top. Anytime ive tried to see why I dont have it just says “select generate netlist” which is a button i dont have. Did I not properly download all the software?
Help>About gives a button to copy information about your version and setup to the clipboard. Please paste that here. Basically without knowing what version and os we can only guess.
Update from might be what you are looking for for V6? I knew the method was updated but I thought the netlist was useful for other reasons?
Application: KiCad Schematic Editor
Version: (6.0.0-0), release build
wxWidgets 3.1.5
libcurl/7.64.1 (SecureTransport) LibreSSL/2.8.3 zlib/1.2.11 nghttp2/1.41.0
Platform: macOS Big Sur Version 11.6 (Build 20G165), 64 bit, Little endian, wxMac
Date: Dec 24 2021 21:51:28
wxWidgets: 3.1.5 (wchar_t,wx containers)
Boost: 1.76.0
OCC: 7.6.0
Curl: 7.64.1
ngspice: 35
Compiler: Clang 12.0.0 with C++ ABI 1002
KICAD_USE_OCC=ON
KICAD_SPICE=ON
I just installed it, so it should be the latest version on macOS. Basically I’m following a youtube tutorial for my very first design and it prompts me to “generate netlist” using the button that says “NET”. I don’t have that in the top toolbar. Sorry if it’s confusing, I couldn’t find my answer online so thought I’d check here
That video is old and that method of passing the netlist to the PCB editor has been obsolete for some time. Just use Update PCB from Schematic.
Generate Netlist is still somewhere for other use cases but you shouldn’t use it in your case.
It was very easy to change the schematic and forget to update the netlist, so now the workflow is direct from schematic to PCB
