Missing connections between items
I am following the KiCAD Like a Pro 3e book and am currently on the LED matrix project. I added a copper fill on the front copper layer connected to the /Vcc net. The problem is that the DRC is complaining about a missing connection between some of the Vcc pins and the copper fill. Why aren’t they connected?
I found the issue. Regions of the copper fill were isolated from one another. I added a few vias so that the copper fill could pass over some of the traces. Everything is now connected.
Sure. I was about to tell you to check of this regions. Am glad that you solved the issue .
