I’m using latest nightly build to import schematics from Altium and it works pretty well, but symbols imported in KiCad lack the contents of the original “Description” field. In my case, this is a problem, because several symbols had ${DESCRIPTION} assigned to the “Value” field so, not importing the original contents of “Description” field results on these components lacking a “Value”. I had to manually assign the correct “Description” on these cases but it would be perfect if the KiCad importer copied the contents of this field too
