this is a simple feature of all PCB/EDA tools, but I’m missing it in KiCad.
Every time if I have to change the layer, I must delete tracks and layout them again.
Can you implement it?
Thanks in advance,
Michael
Thanks in advance,
Michael
In open gl canvas you can simply use “e” to open the track properties. There you can move it to whatever copper layer you want. (It does not create vias though. That needs to be done by the user.)
You can even select multiple track segments by use of the shift key and left mouse button click and use the track properties dialog to change the layer of all of them at once.
You can even use the block select tool for this selection process.
Simply press e again while your tracks are selected to open the track properties dialog.
I tested this in kicad 4.0.6 under fedora.
Switching to open gl canvas is done via the F11 key or in view->switch canvas to open gl
Another option is to use the auto delete track tools of the open gl canvas and just redraw the track as you want.
This button in the left toolbar controls if auto delete is used:
