I have a symmetric hole pattern I want to follow on one side(say the right one) and I’d like to select all those holes on the right after placing them and mirroring them symmetrically across the Y axis,
Is there a standard builtin kicad tool to do it? (Similar to the circular patter tool)
If not, is there an available tool that someone made to do this task?
No problem in v5.1.10 - can make Circular Array and No need for Schematic (the pin numbers remain as defined in the Footprint). I’m not going to bother testing schematic and annotating, re-setting numbers… Since I use Schematics only 25% of the time, 75% of my work is done exclusively in PCBnew…
