Minimum via Diameter Constraint Error – Set to 0.2mm but Showing 0.3mm
I set the board setup constraint for minimum diameter to 0.2mm, but I’m getting an error indicating it’s set to 0.3mm. How can I resolve this?
any kind of help is appreciated
You can also define via diameter using net classes. May be you have some net classes defined.
