Hi, I’m new with KiCad.
I am make my circuit with Kicad and I am using TopoR for autorouting.
My problem is how to set minimal distance from vias.
My PCB maker says that “The space between holes is less than 0.35mm”. Can I solve this problem?
Settings are in Pcbnew
Please post your KiCad version info from Help | About | Copy Version Info
Looks like an older version you are having there.
Application: KiCad
Version: (5.1.4)-1, release build
wxWidgets 3.0.4
libcurl/7.61.1 OpenSSL/1.1.1 (WinSSL) zlib/1.2.11 brotli/1.0.6 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) nghttp2/1.34.0
Boost: 1.68.0
Curl: 7.61.1
Compiler: GCC 8.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
In this case it is Regole di progettazone (Design Rules).
A tip for the future: switch the software you have trouble with to english before making a screenshot to be posted on an international forum.
For kicad this can be done in the main window -> preferences -> language
Als Europäer sind wir da schon sehr flexibel.
