Does anybody know if there’s a mini din 10 pin connector footprint available anywhere…?
Thanks,
Thanks,
You should first give a link to the actual model because there may be 100 different models which are all mini din 10 pin connectors. The outward connecting part doesn’t tell how it’s attached to the board.
Unfortunately all I have is this: https://www.aliexpress.com/item/32994709213.html
There is now sensible way to layout a board without knowing the exact physical parameters of the part. If you don’t have a spec sheet then I’d suggest you purchase the part and measure it before getting too far.
Or buy from a supplier that offers documentation of their product.
