I’m kind of newbie with KiCad and haven’t design circuit for maybe 20 years.
I’m trying to find libraries including footprint for the LM301B/H and Osram Oslon Serie, any lead would be appreciated ?
Maybe I can create the component from existing component that have a compatible footprint?
Thanks for your help.
The most common answer and probably the quickest or at least most helpful way to solve your task is to learn how to make your own footprints. It has been discussed / links have been posted here regularly, so I’m sure you can find a tutorial or video description easily.
The datasheet has some quite useful information, for example the LM301B datasheet has a recommended solder pad drawing in it.
Also consider how to spread out and get rid of the heat generated by the LED - you might want to attach a larger copper zone to the solder pads, perhaps even on both sides of the board with thermal vias, in order to keep the LEDs cool and happy.
