I have two zones on same layer, both with the same NET. I have selected both, right clicked and selected MERGE. The screen flickers for a second as if something had happened, however, the two zones are not merged, the remain as the were.
They are filled prior, and I have tried overlapping them first and also butting one up against the other but no luck.
Am new to KiCad (and loving it, donated twice… …), and Ideas?
This feature is new to me.
I had not seen it earlier in KiCad V5, but that may have been because I have not looked for it.
A boring fix / worakound is to just add about 10 corners to one of the zones, and then delete the other, but the merge thing would be a much more sophisitacted option if it works. properly.
What happens if you make a copy of your project, then delete tracks and via’s and then do the merge?
At least this can exclude if the pads and via’s in the overlap could be an issue.
If you can’t get it to work, then I can have a look at it if you upload the (zipped) project.
You can delete any proprietary stuff from the schematic & pcb if there are parts you don’t want to share.
However, if I create a couple of new zones the same shape then the merge just fine.
I think the issue is with the zone’s having been created as this PCB is an import from Altium CircuitStudio.
Funny how they both fill just fine…just won’t merge…so I guess there is an issue with them somewhere.
just as info:
To prevent such confusion in the future the developers added an info-screen with error-message if merging was not succesful. Currently only available at the v7-nightly builds but could possibly cherry-picked back to v6.
look at gitlab-issue:
