I found that there is Inkscape 1.1. So I replaced my 0.92 with it and got into some unexpected problem.
I suppose my problem is already solved by others so believe someone here just knows its source.
In attached zip there are two svg files.
Till now my procedure was:
- open B_Cu in Inkscape (normally it was F_Cu, but I didn’t wanted to share it)
- press Ctrl+Sift+R to make picture size as graphic size,
- select everything,
- click at Gray 10% (color selection toolbar)
- Shift+click at Gray 10%,
- Import Cmts_User file,
- write 0 in X: editbox,
- write 0 in Y: editbox,
and I had them one exactly at another (provided none of these files had anything more to left or bottom then the other).
Now I end with:
Not sure yet but it looks that now setting in importing X:0 and Y:0 fixes top left corners and not bottom left.
Do you know - may be there is something I should change in Inkscape settings somewhere to work as previously.
In Preferences - Imported Pictures I don’t see anything to tell that I want bottom left corner of picture to be referenced against bottom left corner of actual page in X and Y boxes.
My next step would be to find if Inkscape has a forum
Svg.zip (11.8 KB)
