Hi All
I have to create a filled zone with a precise area, is there a way to set it in advance or simply measure related surface sqmm ?
thanks all
Hi All
thanks all
AFAIK there is no way to set it in advance.
However, when you select the zone, the area can be seen in the status bar
[EDIT] Note that, when changing the zone’s shape, the area is updated only after a zone fill (‘B’).
thank you ! clear to me
