Any trick to make this match the whole string only?
For instance, I want to find 1u not 0.1u
How can I achieve that?
Maybe this is a bug.
I feel this kind of bug always comes back.
Why always wildcards? I think I could achieve that if the field would support regexp. We could drop wildcards completely everywhere and use only regexp, right?
I donât think this necessarily is a bug. A dot usually ends sentences and thus divides words, so â0.1uâ would contain the âwordsâ â0â and â1uâ, at least to the logic most programs use for word search.
However I think there should be an option to only compare the whole text.
Yes, also a comma separate words so probably 0,1u will be the same behavior. As you say most text editors use the âwhole wordâ search this way. Maybe kicad should implement a âspace separated wordâ search or something like that.
Regular expressions are probably not as well know as simple wildcards . . . I do agree though that this should be considered a bug, I donât think itâs logical or helpful to consider a . or , or _ as whitespace.
