Posting here in case anyone’s seen anything like this. A couple of searched got no obvious match.
Here’s what I’m seeing:
Version info below. Pretty sure this is some kind of corruption but after a couple of passes through the .kicad_sch nothing jumped out at me. Thanks for any suggestions.
And my other problem apparently is convincing the KiCad Bot I’ve provided the full version info. I replaced the Sch Ed version with KiCad’s but that didn’t help.
6.0.2 is one of first V6 releases. There were lot of bugs fixed before V6 last version (6.0.11).
Is there any idea to report a bug for V6 when V7 was released an year ago and for not last V6 release?
O I guess we are up to 7, aren’t we? I was just running what’s delivered with Ubuntu LTE 22 (Jammy) and have only just started converting my materials from earlier versions.
6.0.11 is a very good and stable version, on some points better than 7.0 (depends on your needs).
Stay with it, unless you need to import 7.0 projects/files.
I don’t recommend stating off with an obsolete version, you will get “upgrade now” comments to every question.
The 7.0.x series will be kept by many users worried about stability well into 2024 after V8.0.0 is launched
