I need to rotate a whole layout at a particular angle so I can plot it that way. The problem is that when I rotate the board, all reference designators reorient themselves, thus changing the layout.
The solution is to disable the “Keep upright” property on every single designator, but this would take me hours and at the end I will inevitably leave some of them wrong.
Can I disable this property en masse for the whole file? Is there an API or something so that I don’t have to click for hours?
Why doesn’t a “delete” exist in the “Edit text and Graphics Properties” dialog? Example: let’s say I want to delete all Component values, or whatever else, in a schematics, how to do that? I guess it’s possible somehow.
Sir
i am doing hard work to set this function but failed.
Is it Possible to show via Remote ?
First I Open PCB EDITOR then from the Edit menu I chose Text & Graphics Properties & tick check box of Ref Designator.& Disabled keep upright
but when I applied it had no change.
