pigeon
February 13, 2022, 6:53pm
1
Sooo…moved some KiCad folders to share between 2 OS on the same computer and everything went well till I just decided to take a look at the templates option in KiCad and I have an empty folder
I grabbed the files from KiCad / KiCad Libraries / KiCad Templates · GitLab but it seems to be lacking meta date, or I have the file structure wrong (more likely)…any help fixing this?
The Meta stuff is simple:
Create a Folder named “meta” put it inside the Template folder
Put three files in the folder:
info.html (contents is only text with whatever you want)
Do some homework to learn how to set the Path to your User Template folder
Attached is example…
meta.zip (117.9 KB)
system
Closed
May 14, 2022, 7:07pm
3
