Making the layers in 3D transparent
In KiCAD 7.0 is there in the 3D module one can switch off the pre-reg layers so that you can move to the PCB sidewise and see the via(s) going from one layer to at another?
Not that I know of a switch/setting.
Maybe https://de.zofzpcb.com/ as an external 3D-gerber viewer is helpful.
Using v6 (so, I imagine v7 also does what is shown below)…
Four Vias with different connections including Blind and Micro vias… I tied all of them to a Net but, that’s not important… Double-Click the Via to access setting’s panel…
EDIT: Forgot to include: you can Set the Opacity in Pref’s so that you can see the Inner Connections more clearly (and will show the inner Pads/Rings - screenshot…
you can disable board body on the options. Also you have the technical view option, which will show the layers and vias with theirs layer colors.
I mainly to did the transparency bit.
It quite interesting to see how the vias go through the layers.
Thank you for the input.
