Magnetic points not snapping with copper zone
I’ve previously been able to draw copper zones by snapping to magnetic points on pads (i.e. corners, midpoints etc.).
Despite having all magnetic points set to “Always” in Preferences, Grid Overrides enabled (Ctrl + Shift + G) and snapping set to all layers (Shift + S), somehow this behaviour is no longer working and I can’t get a copper zone to snap to the edges of pads.
Interestingly this only seems to be when drawing a copper zone on the bottom layer. When I move back to the upper copper layer, the ability to snap to centres of pads returns.
Is there another setting that I’m missing?
Cheers,
Jono
Can you paste your version info here please, you can get it from KiCad > Help > About KiCad > Copy Version Info
Version information below.
Version: 9.0.0, release build
	wxWidgets 3.2.6
	FreeType 2.13.3
	HarfBuzz 10.2.0
	FontConfig 2.15.0
	libcurl/8.11.1-DEV Schannel zlib/1.3.1
Platform: Windows 11 (build 22631), 64-bit edition, 64 bit, Little endian, wxMSW
OpenGL: Intel, Intel(R) Iris(R) Xe Graphics, 4.6.0 - Build 32.0.101.6078
	Date: Feb 19 2025 17:46:53
	Boost: 1.86.0
	OCC: 7.8.1
	Curl: 8.11.1-DEV
	ngspice: 44
	KICAD_IPC_API=ON
Locale:
	Lang: en_GB
	Enc: UTF-8
	Num: 1,234.5
