I am brand new to KiCad (only installed it a couple of days ago), and I absolutely love it.
Ran through a tutorial from Hawk which was very informative and everything went as expected.
Last night I attempted a new project and everything was going OK until I tried to make a new power symbol (+19V). Don’t know what I’ve done but whenever I press P in the schematic the libraries I get a message “Loading symbol libraries” then a box appears (Choose Power Symbol (1 items loaded) and in the main box all there is is pspice library. No power symbols anymore.
I have tried uninstalling and reinstalling a couple of times but I get the same thing.
Desperate for some help.
Thanks
Mike
Could you detail how you added the +19V symbol?
Does the same happen in a fresh project?
Do you get any error message when opening eeschema?
What KiCad version are you on?
If you are on version 5
In general, you will get the pspice library in the “add power symbol” dialog because it contains a symbol marked as “this is a power symbol” (The symbol for the pSpice reference voltage “0”).
The inbuild power lib also contains symbols made this way which means it should also appear. However, if you have a library in your project lib table called “power” or if you removed the “power” library from the global library then you will no longer get it in the dialog.
