im looking for a special Library Symbol. Its a Connector for RJ50/10P10. Unfortunately i didnt find any symbol in the libraries and in the Internet, so the time is to short to learn how to create it myself… maybe somebody has done it before? i would be really appreciate.
Is this a save site? It looks creapy to me that I have to download and install a downloader, looked like a fake site…you have experience with this site?
Not only will every vendor (manufacturer might be a better word here) have a different footprint for what looks like the same part, but even within the same manufacturer there may be different connector families that have different footprints for the same pin-counts. Be very sure that you have the right footprint for the exact model number that you plan on using.
I hadn’t checked thing thoroughly before my last post. I just checked your data sheet against the link that @hermit provided. Your datasheet is for a vertical connector, and hermit’s link is a right-angle connector. the spacing between the mounting bosses and the electrical pin array may be different between the two. Unless you found the correct connector on the site that hermit pointed to, you might not have a compatible footprint. Be sure your carefully double check your downloaded footprint to the datasheet that you have.
That said, the right-angle footprint might be an excellent starting point for you to modify to fit your vertical component.
