Hi, before I design one myself, I wanted to ask if it doesn’t already exist. But I just can’t think of the name. Basically it’s like a push button as a SMD footprint, but there’s nothing to solder and it can be short-circuited with a simple screwdriver. (Example is attached)
If you only want to be able to bridge it with a screwdriver, then the “solder jumper” as John_Pateman suggested seems a good choice.
For touch switches, there apparently is a new wizard in the footprint editor.
First open the Footprint Editor and then click on:
Which opens the Footprints Generator Wizards. Then select Mutualcap Touch Button
And then you can change some paramaters to which your footprint will be designed.
After the wizard is finished, it puts the result in the Footprint Editor and you can further inspect, modify or enhance your footprint before you save it.
