Load Error on CvPcb 5.0.2
Hello everyone,
I have just installed Kicad 5.0.2 and trying to recover some projects I find the following problem with CvPcb:
Load error:
Errors were encountered loading footprints:
http GET command failed
Cannot get/download Zip archive: “https://codeload.github.com/KiCad/kicad-footprints/Battery_Holders.pretty/zip/master”
for library path: “https://github.com/KiCad/kicad-footprints/Battery_Holders.pretty”.
Reason: “curl_easy_perform()=
Cannot get/download Zip archive: “https://codeload.github.com/KiCad/kicad-footprints/Capacitors_THT.pretty/zip/master”
for library path: “https://github.com/KiCad/kicad-footprints/Capacitors_THT.pretty”.
Reason: “curl_easy_perform()=…
If you neutralize the fingerprint search on github can you solve the problem?
