I loaded them to the kicad libraries as per the published procedure
Problems are
3D viewer is fine for all components but LM338
LM338 appears with the three holes but the regulator is not there.
I went to delete the imported items and find it difficult.
Other info
When I try to reload kicad_mod file for this component the SELECT LIBRARY dialog box does not allow me to open it and select the needed file.
This same SELECT LIBRARY in symbol lib works normally in symbol loading and lets me select LM338.lib file.
There is nothing special about an LM338.
I had a short peek at it’s datasheet, and it appears to be just a beefed up (5A) version of the LM317 in a regular TO220 package.
Then you see it uses: Package_TO_SOT_THT:TO-220-3_Vertical as it’s footrpint, and that footprint already has a 3D model of an TO220 attached, which you can simply re-use.
