Lists in Footprint Lib Browser not resizeable
started after months to use kicad again.
When I try to assign a footprint the library browser pops up and shows 2 lists (to the left) with every
category and footprint.
When hover over the edge of a list the ‘drag arrow’ appears, but I’m not able to extend the list width.
Instead of “Connector_Hirose” I see only “Connector_Hi”.
Application: kicad
Version: 5.0.2-bee76a0~70~ubuntu16.04.1, release build
wxWidgets 3.0.2
libcurl/7.47.0 OpenSSL/1.0.2g zlib/1.2.8 libidn/1.32 librtmp/2.3
Platform: Linux 4.0.4-040004-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.2 (wchar_t,wx containers,compatible with 2.8) GTK+ 2.24
Boost: 1.58.0
Curl: 7.47.0
Compiler: GCC 5.4.0 with C++ ABI 1009
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=OFF
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
thanks in advance
I am assuming you mean the tool found via footprint editor -> view -> library browser
I can resize it under ubuntu 16.04. (Both in nightly and 5.0.2)
It seems to be a bit tricky at times to get the mouse in the right position for it to work. It seems the mouse pointer is changed to the drag symbol in a slightly larger area than the one where you can really drag the boarder. (For me this might be influenced because i run under a virtual machine and kicad is a bit slow to react in it. Meaning my analysis might be a bit different then what somebody gets when running kicad directly on the PC.)
yes it is indeed this tool.
I tried to drag on several corners and edges but nothing happens.
