Linux flatpak install. Can't choose all dirs
I just installed KiCad via flatpak. When I start a new project I can’t choose from all folders on my system (not listed).
I usually store stuff inside a fold at the root dir. “/data” which is owned by root but has read, write and execute rights for everyone. Nevertheless it is not listed in the choose-able folders for saving projects. Why is that?
Because flatpak by default restricts access to a lot of things, including file system, except for some predetermined paths.
Use flatseal or cli commands to give access to kicad to paths you want.
Extremely bad idea, this kind of stuff should be stored in your $HOME directory tree.
The / filesystem will be flattened when you do a system update.
So how do you work with several people on the same project? The unix way is to use folders owned by user:group are for.
I don’t know which kind of distro you use, but mine doesn’t do that…
Explanation I installed just KiCad with flatpak on my Debian, since that still ships version5
First, I stay away from snaps and flatpacks.
But anyway, it sounds like you have a setup with a “master file machine” with all the files, and you let other users access those from their own machines, is that right?
I only run a single-user machine with / on its own partition and /home on a second. This leaves me free to do full upgrades on the system and even reinstall without fearing my data could be lost.
If your /data is on an own partition, you may be able to do that as well.
One way is to is to create a directory under /home/groupname that is owned by the coordinator but has group permissions to members of the group. Nothing says that there must be a corresponding groupname in the users (password file).
In general user files should stay under /home. Top level directories should be left to the system.
+1
Additionally, managing user/group permissions are much easier at this level and incurs no danger of unwanted access to /
