Is there a way to generate an XML BOM from the command line based on a collection of .sch files or a project file? I understand that once the XML file exists, tools like KiBOM can be used. However, I’d like to be able to perform the entire bom creation process in a script. Currently, I’m using the KiCad GUI to generate the XML and then running KiBOM from a script.
Had you try mine script then? It can be perform entire in script with standard python libraries:
You can go directly from .sch to .csv and vice versa (no XML file needed in the process).
