I am currently trying to find a way to:
- put multiple hyperlink (pointing to localy storred pdfs) to one single schematic symbol
- getting the local storred PDF Datatasheet links also working in the exported (ploted)
schematic
Does someone has this working?
I found other threads where they discussed which paths might work
For me all tested paths are working in eeschema itself, but not in the exported pdf.
Might this be a bug or missing feature or does someone knows how to do this?
Seth_h
#2
Check to make sure that you are using Acrobat PDF. Many PDF features are not implemented in other viewers
gkeeth
#3
Make sure you’re using Plot to generate the PDFs. The features you mention won’t work if you use Print with your OS’s print-to-pdf driver.
yes, I used Adobe Acrobat PDF
yes, I used Plot, I will try to create a reproducible demo
I created a bug / feature request and added a demo:
