1-2 months ago I added to my schematic diagram a field which I had named “Value2”. Now I wanted to add another one called “Descr1”. But when I add it using “edit symbol fields” and then save and close that table, then re-open it, that field has not been added. I have tried saving the file and closing and reopening.
Right now I am using 6.0 nightly because I want to keep compatible versions between two computers. One is this one running Windows 10 and the other is my old lab laptop running Linux Mint.
But if updating to the latest stable version will fix this then I will try doing so.
Application: KiCad Schematic Editor (64-bit)
Version: (6.0.0-rc1-119-g126563c839), release build
wxWidgets 3.1.5
libcurl/7.78.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 19043), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Nov 22 2021 12:00:10
wxWidgets: 3.1.5 (wchar_t,wx containers)
Boost: 1.76.0
OCC: 7.5.0
Curl: 7.78.0-DEV
ngspice: 35
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
