Hi @crusader27529. Which OS are you running?
I’m using Windows, and i haven’t experienced too many issues.
I’m using my own libraries, and they are stored in a different location to the installation.
So in my case, the libraries themselves are stored at:
- G:\ApplicationFiles\KiCad\Libraries\Footprint
- G:\ApplicationFiles\KiCad\Libraries\Symbol
As you will know, the configuration of symbols is set by “project_name”.pro (currently) in the project location and Footpints are set by the fp-lib-table.
There is a “global” fp-lib-table stored somewhere like C:\Users"user"\AppData\Roaming\kicad\ which is created when KiCad is installed.I don’t use the “project” fp-lib-table, so i won’t mention it.
What i do is keep “master copies” of the .pro file and the fp-lib-table file in G:\ApplicationFiles\KiCad\Template and update only these files. I do this so that KiCad updates/reinstallations do not affect my settings.
If i update the “master” files, i then run a batch file to copy “master” fp-lib-table to C:\Users"user"\AppData\Roaming\kicad\ (overwrite it) and the “master” .pro file to C:\Program Files\KiCad\share\kicad\template (overwrite it). It can be done manually of course.
The fp-lib-table is not project dependant, so it can be updated when a project is ongoing and new/updated footprints will be available immediately.
The kicad.pro file in C:\Program Files\KiCad\share\kicad\template will be used when you create a new project, but you can always update mid-project if you overwrite the existing one in the project folder:
- Copy updated kicad.pro file from C:\Program Files\KiCad\share\kicad\template to project folder.
- Delete existing .pro file in project location.
- Rename kicad.pro to project_name.pro
I believe that symbols in future releases will be handled using a similar lib-table concept.
Regarding environment variables:
KISYS3DMOD is G:\ApplicationFiles\KiCad\Libraries\Footprint
KISYSMOD is G:\ApplicationFiles\KiCad\Libraries\Footprint
KIGITHUB is https://github.com/KiCad
Set in “system variables”
Once set correctly, they shouldn’t be an issue (i think even an uninstallation will not remove them, not sure).
