Library management
Hello everyone, I have a question concerning the management of libraries in Kicad. Since version 5, a tool allows you to manage libraries, for symbols:
Following the projects, we do not systematically need all the libraries and in order to reduce their numbers we can validate or not those that we want to use:
My question: In the example above I don’t need the MCU libraries, rather than tagging each library one by one is there a trick to tag multiple libraries? If not, could we not have a button for multiple marking?
Thank you.
Vincent.
Why not use then the other tab for Project Specific Libraries?
Althoug the un-tic several libraries at a time issue is not solved…
Hi Pedro, just to reduce their number in the list when you need to select a component:
In this example, when you select “Place Symbol”, the list includes ALL libraries, global and specific! Here 3894 articles are loaded … I don’t think I need all these components in my project …
Sure you don’t. None of us do, I think.
It depends of how fast is your computer if it is a matter of delay.
Usually I know which library I need for a given component. And there is also a filter field on top, very useful indeed.
Yes the filters are good. It is not a problem of machine speed, it is just a request to know if something exists because today the libraries are monstrous of resources and for example by marking a group of lines in the editor one clicks or press the space bar to mark or not the libraries that will be used.
In version 5.99 it’s possible to toggle all of them at once by pressing spacebar when they are selected. This doesn’t work in 5.1.
Hi Peter, I just tested, indeed version 5.99 covers the subject!
Okay, so that will be covered by release 6 !
Great !
Vincent.
Who’s Peter? ---------
Sorry eelik mistake in typo !
