Library editor in vers 5.0.2
Hello
I used the vers 4.0.7 for a while.
For copying a symbol from a lib to my local project lib,
I used the following way in symbol library editor:
  1. select working library
  2. load component
  3. modify if desired
  4. select working library (local lib)
  5. update
  6. save
In the docu of vers 5 chapter “Transfer symbol to another lib”
there is the same explaned but new icons.
After changing to vers 5.0.2 then I try the same.
At the beginning the Symbol Library Editor showes in the top line:
“There is no library selected”. Ok.
But there is no icon to “select working lib”.
I do not know how to select a working lib for further access.
Is the docu outdated, or what do I wrong ?
Regards
Hi
In v5, use copy/paste (right click).
Now it works !!
Thank you much.
You might be interested in this Tutorial: Tutorial: How to make a symbol (KiCad v5.1.x)
