Libraries on Schematic are empty - Windows 10
I installed KiCad 5.1.4 on Windows 10.
After installtion I wanted to start my first test project. In the schmatic editor there are no libraries shown.
I know that I can manage the libraries myself, but therfore I must cklick every .lib file manually to get it in the pool. That can’t be the right way for my opinion.
Is there a possibility to tell KiCAD to import all libraries in a folder?
thanks
Nope you can select multiple libs to add using shift + click.
See Library management in KiCad version 5 (section adding library to the library table)
Sorry, you’re right. I used the + Icon to add libraries, ther I can select only one.
But by using the folder icon right beside I can select all together and it runs.
thank you for the fast help!
