I’ve been playing with applications for 40 years and most times my rule of thuumb is that I should be able to get 70% of the functions without resorting to the manual… KiCad fails this test for me in terms of componentz and libraries
The problem as I see it is the accent is on libraries, and not the components.Just try to open up an existing and save to another library in eschema to see the problem… Even the program is called a " Part Library Editor"
I believe that the accent should be on the component, the library is a folder containing components. I know I may be a little naive here in the inner workings of Kicad but I am having difficulty understanding why libraries are so featured in the Kicad make up, and not components…
I also think that that the definitions are wrong, footprints Yes but schematic representation as a component No
So I propose Schema and Footprints
Enclosed is a flow chart of an intuitive method to create and save both options. If it looks familiar it is because it is. Open up any Word or Excel to see the arrangement. As is the New/Save/Save As functions I am familiar with in Cut2D, Mach 3, PCArtist, and a plethora of other programs I have used.
Please developers, in version 5, address the difficulties of the component library disconnect…
It is not intuitive, It is not easy, It is not commiserate with the level of professionalism that is shown in other parts of the program FLOW CHART FOR COMPONENT SCHEMA OR FOOTPRINT EDITING.docx (40.4 KB)
Second, this is a support forum, not a developers forum. If you want to have your voice heard and probably dismissed 5 seconds later this is the place to do that: https://lists.launchpad.net/kicad-developers/date.html
Third, most of your concerns are essentially non existent.
If you want to run components please use the search function with the term ‘atomic’ and you will find that KiCAD also allows this kind of workflow, to define components.
It’s all there.
You just have to learn the ropes and maintain your own personal libs, as the official ones will not be able to ever support this kind of setup.
Some more background info, so you get WHERE KiCAD comes from…
KiCAD started as a collection of tools in the french language.
Over time this got morphed into what KiCAD is now.
Schematic symbols will be called that.
Layout footprints will be called that.
Components/parts exist in the form of links and only as a combination of symbol + footprint + meta information (partnumber, etc. pp).
KiCAD evolved from hobbyist users, who wanted to be able to use any set of symbol with any (pin matching) footprint. That’s why KiCAD does have this lose connection and no dogmatic view of a singular atomic component.
That’s how the KiCAD world looks at things.
Good luck and if you run into trouble defining your own atomic parts, don’t hesitate to speak up. We’ll be glad to help where ever possible.
If I was a German speaker, I would coin a word that means “culture shock when encountering KiCad for the first time”. Maybe there is already
I am a software developer. In my spare time I develop little bits of software for home use. I was recently revisiting software I first wrote exactly 30 years ago. Looking at it, an immediate thought was why the heck did I write it like that?. There are several reasons, my own knowledge and skill has developed a lot, PC hardware has changed enormously (no longer do I need to pack all data into a 64KiB segment), programming languages and development environments have improved enormously.
Anyway, it was quite interesting to rewrite code that was originally written for DOS and character mode GUIs, but because it is for my own use, I don’t need any backward compatibility, I can completely change the interfaces and file format to suit a 2017 PC. Also, I only have a few 1000 lines of code, not millions.
KiCad started out with a DOS program, and has grown since. Ideally, we would start with a blank sheet of paper and redesign KiCad, According to https://www.openhub.net/p/kicad/estimated_cost, KiCad has accumulated 860,000 lines of code, costing $12 million or 233 person years. KiCad doesn’t have anything like such a budget to spend on creating new code.
TLDR; because legacy. We don’t have a magic wand to create new code.
There are some things you can do that will make a difference:
if you can code, contribute patches to Kicad
or create external tools which work with existing KiCad files
otherwise, donate to developers who can work on your ideas
Most libs in the official symbol libs hold parts that i would define as atomic. (Only the Device, Switch and Connector libs are fully generic. All others should hold atomic parts.)
Every part there is identified with the manufacturer part number and the footprint field is set. (Or at least this is the goal. A lot of symbols do not yet have the footprint field set. But we are getting there.) This approach allows for footprint reuse. Take for example the soic-8 footprint. That particular footprint is used by a lot of different devices.
The footprints are generic where they can be generic. (This does reduce maintenance effort.) We allow for manufacturer specific or even part specific footprints. (Example for the former are the footprints starting with Bosch_ in the LGA lib, for the later have a look at the relay lib.)
What we can not provide is the inclusion of your personal house part number (self explanatory.)
Or the inclusion of ordering information. (Who would ensure that this is valid at all times for all users. Too much maintenance.)
You contradict yourself in the same paragraph… Very few of the parts in the official library are atomic, because the vast majority use generic (shared) footprints. An atomic part has its own, dedicated footprint which is not shared. It is not a stated goal anywhere in the KLC to create atomic parts, it is more incidental for certain components with a proprietary footprint.
I understand your desire to promote KiCad, but saying things that are really quite misleading is not helping anyone.
What would be the benefit of this? As far as i can tell a SOIC-8 is a SOIC-8 no matter what part it is used for.
I see one major downside to having one footprint per component instead of one footprint per package. (maintainability)
Lets imagine one sets up a lib that way.
You discover later on that your SOIC footprints (with exposed pad) should get a slight modification to the paste layer because your assembly house found that they could increase yield that way. Now you need to go through your lib and change all SOIC footprints. There is a high danger of you missing one of them. (If they are atomic is it even easily possible to find all SOIC footprints?)
Of course if you have a MEMS sensor that needs special treatment then you will make a specialized (or atomic) footprint for that sensor. But this does not really make sense (to me anyways) if you do it for the logic chips. (You would need as many soic-14 footprints as there are logic symbols in the logic lib. All of them holding the same data.)
What term would you use for symbols that are fully defined and represent one component, but point to generic footprints?
Semi-atomic? You select a component (symbol) and get also a footprint automatically (this is what people often want and are happy with), but the footprint is shared. Or unidirectionally atomic? One automatic footprint for one symbol, but many symbols for one footprint.
Looking at the KiCad FAQ and KLC, I see that some confusion has crept in. Both documents have a misunderstanding about atomic parts They both refer to “atomic parts” but get the concept wrong. Someone (maybe Wayne), coined the term “fully defined part” , and then he or someone else decided that is the same thing as “atomic part”, but that is wrong. At best it is compromise between generic and atomic parts.
It is true that an atomic part is “fully defined” but it is important that an atomic part is also self-contained, unlike “fully defined part”. An atomic part has a 1:1 relation between symbol and footprint, fully defined parts are only many:1
Why is that important? Because of version control. In production it might be necessary to change the footprint properties for a specific component, and you don’t want to propagate those change to any other.
Therefore we have 3 types of part : generic, fully defined (but probably a shared footprint), and atomic (self contained). The KLC (and official libs) might have a goal of full defined parts, but that is not the same as atomic parts.
[quote=“rodmcm, post:1, topic:8879”]
[/quote]Well, 5 is in feature freeze so it’s pretty much a done deal. As far as the 70% rule? Playing around with applications for 40 years may mean nothing if you have little to no experience with ECAD and you don’t tell us that. I tried gEDA and it was very apparent that the people developing it worked with it. I loved many elements of the work flow. As far as it went. With Kicad you at least have developers that use the software and make the decisions about its direction and not some marketing department.
To your point. The libraries have been a bone of contention for some time and that is being worked on. Many simply don’t care because they plan on vetting every single part they use because it is their axx on the line if something fails. This is independent of Kicad. As such, the existing structure becomes second nature to them. Change it too much and the existing user base might not be very happy.
You want the schematic designer to choose generic functions such as NAND gate or OPAMP. This is the design that they simulate and verify.
The PCB layout engineer will select the actual parts and package the symbols together and assign slots. PCB will also select technology such as surface mount top or bottom, through-hole 1 sided,2 sided etc. Each one of those has a different footprint and pad-stack.
The symbol has no way to know what footprint will actually be used on the board and each board will be different.
I may disagree about who performs the specific tasks, but my personal observation and experience supports the basic point: “Design” is almost always a series of activities where the later tasks add increasing amounts of detail to what was done in earlier tasks.
I feel inefficient and frustrated when I am forced to specify all the final details too early in the process. When I start to create a schematic I may have only a fuzzy idea of what value is required for some parts. Requiring me to concentrate on details down to construction and packaging, at that stage, actually hinders my ability to concentrate on fundamental questions such as values, power and voltage ratings, etc.
Yes, One thing that managers need to under stand is that if you ask an engineer to go back and change a decision that they made in the past then they must now go back and revisit every decision that they made since then. Thats why changes take a longtime to get right.
Thanks for the comments… However I was not really talking about atomic entities but about a standard coherent methodology in the creation of a new, modifying an old, or copying an entity, be it a schematic symbol or a a footprint.
The present methodology is non conventional, not intuitive to me, and differs between a schematic entity and a footprint hence the standard flow chart I suggested…
As to having separate footprints to schematics I like it! I can craft my schematic representation to the job at hand, especially with processors where a design could need analogs to the left and outputs to the right.
As far as cvPCB is concerned I only use this to check that all items have an assigned footprint. A simple list would suffice for me
But it think the reason why people make atomic resistor parts is because they have ordering information stored directly in the symbol (for bom)
I would however suggest to have house part numbers, that use a combination of the hpn field and the value to generate (via a script) the detailed hpn and from that the ordering information. (How should the designer know during the design process which resistor is best suited for the people in purchasing. As long as the electrical and mechanical requirements are met.)
The hpn can for example be: R_[size][value][tolerance] Then you can have the hpn field for resistors pre filled with R_0603_[%V1]_[%V2] and the script knows to split the value field in resistor value and tolerance.
The problem here might arise if the designer enters value, tolerance pairs that are not in the approved list. (Can not happen if the designer can only choose from a restricted set of fully specified parts.)
Well I just have to say I couldn’t agree with anything in the first post. Developers Kudo’s to you. I downloaded Kicad and produced my first PCB in 4 hours. Damn thing worked too. OK it wasn’t that complicated, it only had 100 components. I only had to make one component in the PCB foot print, which was actually in the library already, I just didn’t search well enough.
So I read all this stuff about the libraries, and discord and I say “The libraries are damn impressive”. Its is however great to see the aspirations to get things better.
I’ve been building programs for 40 years now, and where does Kicad rate… Kicad is awesome. OK some parts I find a little clunky, but then Altium was also clunky in aspects, and so is Eagle. Maybe those 2 later ones are better now, but I don’t care… Kicad is awesome.
Having produced my first Python 2.7 GUI app I’ll be joining the developers soon, I did look at some of the code…and my god where do you start.
My wish list would be to add simulation to the schematic, at least just the analog stuff, but for now truck on developers Kudo’s to you.
Agree that is a very workable solution. I do something similar by using a BOM script to bring in all in the footprints and values - I then extract the parameters from my component directly - so I can then do a query for parts that meet my search criteria from my stock database. This is ideal for ‘jellybean’ components. I can just place a R_0603 and set its value to say 4K7 1% and I can use the script to do a stock search with those parameters .As a one man band, I like the way that I can also tie this in with my stock management. In my case, I use PartKeepr for stock control - this runs on a mySQL database and has my ‘approved’ parts and stock levels and can pull in part parameters and order numbers/pricing directly from Octopart.
The advantage with this sort of approach is that you don’t need to hard code an PN into a particular component and are therefore not tied to one specific product. The actual component choice can be done by matching the component spec to the parameters in the database - so you might have a choice of 4K7 resistors from Panasonic or Yageo or whoever.
The BOM report also identifies non-stock items which can easily be added and so provides basic MRP functionality too. This way you don’t need a specific Resistor or Cap library - you can simply place the component and defer the choice of the exact item from stock until later.
