I need a library for as6c62256 SRAM chips but I’m having trouble finding any.
That’s all.
In the schematic editor, if you press the shotcut key A, (or Menu / Place / Add Symbol you can add a search string in the text field, and by entering just the base number, you get 3 variants of the same IC:
You do have to check if this also works for your variants.
But if needed, a schematic symbol is very easy to modify in KiCad’s Symbol Editor if needed. I do this for example for each microcontroller I use, just to get the pins in the right place so they fit better in the schematic of my current project.
