Length Tuner Gives Innacurate/Variable Lengths for same trace
The length tuning tool gives different lengths for the same trace depending on which part of the trace you hover over. See the example screenshot. The length tuner reports this trace to be either 65 mm or 62 mm depending which segment you hover over. Other examples are more extreme (not just a couple of mm difference each time).
These traces are connected end-to end but jump layers a couple of times. This is not an isolated example seems to happen frequently, but not for every trace
Surely this is a bug, what is the work-around for this?
FYI this is Kicad V9
Thanks
Which one ?
Can you paste your version info here please, you can get it from KiCad > Help > About KiCad > Copy Version Info
Check if a nightly or bugfix release of v9 has addressed this. You can also report the issue here:
This is a known bug:
Hi
Version: 9.0.1, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
OpenGL: Intel, Intel(R) UHD Graphics, 4.6.0 - Build 26.20.100.7372
Date: Mar 30 2025 01:11:30
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_AU
Enc: UTF-8
Num: 1,234.5
So it sounds like the length tuning tools are not usable?
