LDO 5V to 3.3V
I’m trying to plan and sketch an LDO (low-dropout regulator) supply circuit, where the input voltage is 5VDC, and the output voltage should be 3.3VDC, with a power of at least 3.3W.
I repeatedly encounter a problem related to a server amplifier.
I would appreciate it if I could get some help on this.
Attached is a picture of the fault and the circuit.
thanks.
LM358 is . . .
a Dual OpAmp . . . you have the second OpAmp not shown and not connected. You need to show it and mark the pins as not connected.
Actually it’s best if the unused OpAmp unit is connected as a voltage follower configuration or similar.
Leaving it unconnected will cause problems (noise, overheating, etc.).
Sources:
  1. I’ve been burned by this before :slight_smile:
  2. TI has a pretty good app note on this: https://www.ti.com/lit/ab/sboa204a/sboa204a.pdf?ts=1739959609657
Sure, I was addressing the KiCad issue rather than the potential electronics issue :wink:
Does the LM358 really have enough bias current to use a zener without a resistor?
There are many design errors, but I will only permit KiCad relevant discussion. This is NOT an electronics homework solution forum.
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
