Hello!
I have the following problem. I haven’t used Kicad for a couple of months, and I wanted to modify a designed I produced earlier. As I wanted to change the location of the ESD diodes to make them closer to the connector, I tried to press a few keys when hovering on VIN, and the result was as below:
Before:
Hello!
Thanks for your reply. I have updated, but found out weird problems in the nightly builds. Is there a somewhat stable version that would correct the above problem and yet being stable enough for daily usage?
I noticed that the current version is called 5.1.2_2. Does it address the problem?
Thanks,
The workaround I found was it relates to a edgecut arc surrounding where you are laying out. So while routing just change the arc to anothet layer. Say front silk. And then it wont interfere until your done. Then change its layer back
I don’t know the version but the install file was kicad-r13741.30ec895c9-x86_64
I didin’t take notes of what wasn’t working, but I remember for example that using a simple c to copy an element in schematic didn’t work anymore. It was ctrl-c instead. The good thing is that it complies to the standard of all programs I know. Hopefully it’s a move to a kind of harmonization of commands in schematic and layout.
