Layout - Cannot move graphic
Hello Group -
I created a customer logo using the image converter, and placed it on the board. It is on the bottom silk layer. I locked it.
Now I cannot select it. I need to move it but absolutely cannot select it.
I have tried using the selection filter and nothing is selected when I window over it.
I also did CTRL-A (select ALL), then moved everything, and that logo didn’t budge. It is locked so I expected to get the “override locks?” dialog. But nothing.
Are there any other tricks I can try?
I may just try to select all, then copy, and paste into a new layout.
Thanks in advance
“Locked Items” in the selection filter (bottom RHS) needs to be ticked to allow unlocking and movement.
Try that.
Thanks but there is no such item in my selection filter. I am using version 7.
Ahhh… found it. It’s not in the selection filter that you get by right-clicking, but it is in the window on the bottom right, as you said. Thank you.
I’d not noticed before. They’re awfully close.
Right click - Filter Selected Items.
Right lower corner - Selection Filter.
