Agreed on all points. I want the ability to “save” sets to the side and rename them. As to the ease of use of the buttons. I agree that it’s difficult to determine what they do. Perhaps a downward arrow on each of the thee push buttons and an up arrow on the pop button (I tried to do that with ASCII ^ (pop) and v (push – and the dashes in “-v-” indicates coming from both Layers and Renders and pushing onto the stack)?
Also the tool tips (which you don’t get from the picture, but you do get when you hover over each button) are:
Another release around the corner, possibly by this weekend.
Integrating saved / named view sets. You’ll be able save any viewset on the stack and name it. It will appear as a selectable viewset on the right, and it will persist between kicad runs in ~/kicad/viewsets
This seems to be reaching and end in development. There are no other features that I plan to add after this. Any ideas or thoughts on what would make this more useful?
I put the stack on the right, and the saved view sets on the left. The stack automatically gets the name [layers]/[renders], without extra labels. This way the label in the stack is small, and any extra room can go to the named set on the left.
Here is a little guide on the stack label format:
3/5 - 3 layers are visible and 5 renders are visible
2/ - 2 layers are visible and renders will be unchanged
/4 - layers will be unchanged and 4 renders are visible
0/3 - 0 layers are visible and 3 renders are visible
Note the subtle distinction between “/4” and “0/3”.
The “tooltip” for the stack buttons list all the visible layers in the set:
Well, I couldn’t wait. I’ve updated the files on github with the latest update. Includes naming and saving ViewSets. An updated README.md explains in detail how to use the control.
Please let me know how it works and if you find any bugs. It’s been lightly tested in Windows KiCad nightly.
LayerViewSet has been updated. There was a bug that prevented loading different viewsets from different buttons. It should work much smoother now.
Because LayerViewSet can load Layers and Renders separately or together, you can do cool things like set buttons for quickly changing the Renders. This, for example, has buttons named “Show All Renders” and “Hide All Renders”. You can set any combination of layer visibility, render visibility, or both, that you want; name them; and they will persist between KiCad sessions:
